115 Merc no start after running a 10 min shutdown
The Cheif
Howdy
Working on 115 merc this week and has a no start after running and a 10 min shutdown
im thinking heat soak trigger of vapor lock unless any one knows any tricks?
thanks cheif:eek:
douglas1978
Re: 115 Merc no start after running a 10 min shutdown
what year is the motor, wiring in good shape?
The Cheif
looking at boat tomorow runs good can restart right away after shutdown but if you let it sit for 10 min nostart
Chris1956
put some ice on the trigger if you can, and see if that helps.
The Cheif
Thanks turns out the motor is a 1975 with a distibutor wow called merc for a rotor and if you can find one its 350.00 :( plus major surgery to replace eeeeeeooooowwwww any one know where you can get parts and a manual?
Chris1956
distributor rotors and shafts are avail on the web for $220 or so. You might google the part number and see what you get. Try oldmercs.com, vintagemercs.com, CDIElectronics.com
