1992 V4 yammy - running beautifully yesterday to fishing spot.  Started well and came back at between 4,000 - 5,500 rpm great for 35 mins.  Pulled it back to idle at marina from 5000 rpm and it started to die.  Sounded like it was choking - opened throttle gently but even at full throttle it did not increase revs at all.  Put in in Neutral and used fast idle lever and it reved up.  Then it died when I went to put it in gear.  Tried to re-start and would only re-start with choke (this is sunny Queensland in 35 degree celcius heat and hot motor!).  Only just got it into Marina with it choking and it died as I touched the jetty.  Took it home and flushed motor and it started great and ran (without load) well.  At not time was there a lean sneeze or backfiring heard.  What gives?  Any thoughts.  I wondered whether it needs a carb clean.<br /><br />Thanks for your help
