jimmbo
- May 24, 2004
- 14,237
The optimum Trim angle for speed is just below where the boat begins to Porpoise, Generally the fast you go, the higher you can trim. However there are times when you will be running at Trim setting other than that. Running with the Waves, you might want to Trim Out more, while running in to the waves, some boats do better trimmed in, while others, trimmed out. Running at speed, trimmed in Too Much, can create an unsafe condition where, with the Bow digging in too much, can become a Pivot Point when you try making a Turn, and can cause the boat to Flip.
Trimming out too far allows Air to get to the Prop, and loss of Boat speed, with an increase in RPM. Some Props do better than others and can retain the Grip on the Water
As you trim an engine, your will feel a difference in the Steering. Trimmed in the Boat will want to turn to Starboard, Trimmed out, it will want to go to Port. Running Flat out Trimmed out, a sudden drop in Power will have the boat lurching to Port.
