gmstreetmaster
- Jul 6, 2005
- 12
I got a blue band 70's 6 cyl 115 engine. I rebulit the carbs, put new wires and plugs on, I checked the compression (125 on all cyl) and verified that it is sucking air through the carbs while cranking. I replaced the coil since the factory one was weak. Now i get great spark. I checked the reed valves and they are all springy. I have tried choking the engine until gas comes out of the carbs, sprayed a gas mix into the carbs and nothing is getting this thing to run. I had it running about 2 weeks ago after about an hr of tinkering. THe only way i get any response out of the engine is if i take out each plug and squirt gas in the cyl then put the plugs back in an hit the starter. The engine will run for a second or 2 but not stay running. Im pulling my hair out on this pyle and id like to go fishing one of these days. Anything Im missing here?
