12 volt accessory plug
jlsmith
I have a 2003 G3 170hp and the 12 volt accessory plug is not working. Does anyone have a diagram of which fuse goes it. I thinks checking fuse would be a good place to start or any other ideas what could be wrong. I have no power to it to charge my cellphone. Thanks
the receptacle probably is rusted out (common issue). check for voltage at the connections at back. if you have voltage there, however not thru the receptacle. then replace the receptacle.
I installed stainless receptacles on my boat a few years ago and I am already replacing them as the positive button in the bottom has long since sucumb to corrosion.
