afdcaptain
- May 31, 2011
- 4
Ok lets try this again with a little more information. I have a 1994 Bayliner Capri 1700 with a 120 hp outboard force. The boat was my dads. The lower unit went bad. He purchased another lower unit for it. On the original lower unit the exhaust came out through the middle of the prop. The lower unit he purchased the exhaust comes out a v nothch type thing above the prop. The Mercury dealer said it didnt matter and would still work. The boat ran fine before this happened. Now that they have installed the lower unit on it it will not run with the cover on it. Take the cover off and it runs fine. put it back in and it will stall. I think it is due to exhaust fumes choking the carbs out. My question is, is there something at the lower unit that they could have done such as tore a gasket or something that is the problem.
