120 Mercruiser 2.5L - No spark
Mercruiser 120
Alldodge. Is there a way to test the black wire from negative on the coil to the distributor and screws on the side of the breaker points
alldodge
Check continuity, remove wire from coil and attach meter probe. Connect other probe to the points, If points are open the meter should read infinity after a few seconds, if closed will read zero ohms
Mercruiser 120
Thank you for everything, the tach wire off of the negative on the coil. Starts right up. Sounds great with the new carb rebuild
alldodge
Ok Tach is shorted out or wire is grounding somewhere. Good to know she's running
Mercruiser 120
alldodge. Do I set the timing like I always do, 8 degrees BTDC? Or do I have to set base timing? How do I do that
Mercruiser 120
There is no base timing mode or shut for your distributor. Just point a shoot to set timing
Alldodge sorry another question
I installed clear gas line from my fuel pump to carb to see what is going on.
It looks like there is air bubbles(big) once every foot at idle at the dock. Idles rough but stays running and better at higher rpm.
Is this a clamp loose?
alldodge
The bubble shouldn't be the issue with running. Only if there were a lot of bubbles it would effect running.
I couple small bubbles every once in a while I wouldn't think much of. More then that, might be the pump diaphragm, hose fitting or hose clamp
Mercruiser 120
Thank you
alldodge
Yes on mixer screws. Going CW on the idle adjustment screw just opens the throttle more
Mercruiser 120
Alldodge.
I have the 120 going good. After the rebuilt carburetor and the shorting tach wire, it starts up. Just pump and start. Goes faster then it ever has.
I went out set the timing. I bring it back, then into neutral. It will idle(not perfect) then if I leave it, it will slowly get worse, eventually stall out.
Is it my idle mix and idle speed screws need adjustment
alldodge
Check fuel pump pressure
Need to get a gauge to read 4-7 psi and place between pump and carb. Its either running out of gas due to a bad/weak pump or drawing a vacuum due to antisiphon valve, would be my guess
Mercruiser 120
It was sucking air. I have clear, real gas line from pump to carb. I put a new straw into the tank and sealed the anti-siphon threads. Not a bubble in the line. I bought a vacuum gauge to set the idle screws. When I put the vacuum gauge hose on the manifold spit I can’t get the engine to stay idling well enough(hardly at all) to adjust the idle mixture screws.
I will put the pressure gauge between pump and carb to make sure I’m at least 4 psi.
Mercruiser 120
Also, if it runs mint once I get it into gear up to WOT, does that mean I have the right pressure coming out of my fuel pump
alldodge
In most cases yes, so long as its not running lean
A motor will run great when running lean. The lean condition will damage the motor. It probably is not running lean but you can do a simple check. Run motor at WOT or close to WOT for a few minutes. Slow down and don't idle much at all and shut motor OFF. Pull a few plugs and see if they are white. White is lean and cream or brown is good
Having new plugs will require running them for a few hours at regular speeds to get them to start showing actual burn mix
Mercruiser 120
Thank you so much. I think I have it perfect. Idling, then going fast, been 3/4 throttle for 20 minutes. I bring the gear shift back and the motor conks out. What am I doing wrong
