125 force help
Kahrmar3912
Can not get motors to spin at sufficient rpms to start . I have to new fully charged batterries all new cables new perko switches And i still cant get them to do any more than barely spin one or two revolutions. What can i try next I have 12.3 volts at the solenoid the starter engages and disingages. :confused: :confused: :confused:
Twidget
Re: 125 force help
Welcome aboard Kahrmar. :D <br /><br />You might want to post your question in the Force&Chrysler Troubles and Repair forum.
JB
Re: 125 force help
Moved to Force troubles
imported_LakeRunner
Re: 125 force help
Seems to me I had this problem when my stator went bad although this is also symptomatic of a bad starter. If you don't have one, get yourself a force service manual. It has all of the tests to help you determine where the problem is.
Kahrmar3912
Re: 125 force help
Originally posted by Lake Runner:<br /> Seems to me I had this problem when my stator went bad although this is also symptomatic of a bad starter. If you don't have one, get yourself a force service manual. It has all of the tests to help you determine where the problem is.
RRitt
Re: 125 force help
new battery and new cables. Solenoid pulls in and starter spins but not it does not spin fast enough or long enough to start engine? Would that be accurate?<br /><br />my first check would be battery and starter connections inside engine. They are easy to overlook but can cause above problem. There are four of them including positive to relay, negative to engine block, and relay to starter. If all good then an auto electric place can rebuild your starter for about $35.
Kahrmar3912
Re: 125 force help
Originally posted by RRitt:<br /> new battery and new cables. Solenoid pulls in and starter spins but not it does not spin fast enough or long enough to start engine? Would that be accurate?<br /><br />my first check would be battery and starter connections inside engine. They are easy to overlook but can cause above problem. There are four of them including positive to relay, negative to engine block, and relay to starter. If all good then an auto electric place can rebuild your starter for about $35.
Kahrmar3912
Re: 125 force help
Starboard egine now runs port has same problem Cleaned all motor connections.
RRitt
Re: 125 force help
describe the problem in more detail. it shouldn't take that many rpm's to kick-off if compression, spark, and fuel are good. saying that it "doesn't spin fast enough" is too vague.<br /><br />could be stuck rings causing low compression. could be last year's gas plugging up jets, could be choke not working, could be timing shaft sticking and spark at wrong time, could be old starter, could be , could be, could be.<br /><br />a more detailed blow by blow description of events, actions, and results might narrow the list down.
Kahrmar3912
Re: 125 force help
Originally posted by RRitt:<br /> describe the problem in more detail. it shouldn't take that many rpm's to kick-off if compression, spark, and fuel are good. saying that it "doesn't spin fast enough" is too vague.<br /><br />could be stuck rings causing low compression. could be last year's gas plugging up jets, could be choke not working, could be timing shaft sticking and spark at wrong time, could be old starter, could be , could be, could be.<br /><br />a more detailed blow by blow description of events, actions, and results might narrow the list down.
Kahrmar3912
Re: 125 force help
crank spins freely by hand. The starter doesnt even spin fast enough to kick Motor completes 2 revolutions at a very slow spin and then disingages identical to the way it would spin if the battery was dead.
RRitt
Re: 125 force help
swap starters between engines. if problem follows starter, then take them both to an autoelectric shop. they will rebuild both starters for about 1/2 of what the marine store will charge you for just one. It just a bosch. The only special about it from boat store is the humidity resistant glue they use on the marine price tag.
RRitt
Re: 125 force help
they have to use waterproof glue. anyone who buys one is taking a bath.
Kahrmar3912
Re: 125 force help
speaking of bath i just went to a marine mechanic to have him relace my trim pistons ouch
