sjdwallingford
- May 17, 2010
- 17
I?m in the midst of trying to rebuild the two carburetors on my 1987 Force 125HP and have two questions:
1. How is the bypass tube No. 51 connected to the carb (see attached diagram). I?m trying to remove it. The diagram indicates that it is inserted from the top, but it is not clear how it is fastened ? e.g., is it threaded in, interference fit? I?ve tried to tap it upward and turn it, but it?s not moving. If I knew how it was installed, I?d be inclined to use more force.
2. When attempting to remove those little brass plugs/caps (e.g. No. 48), I pushed a couple inside the passageway they were plugging. Any suggestions for extracting them?
Any help would be greatly appreciated. Thanks.
