125hp force 80s model thermostat?
You didn't say you had seals leaking???
If it does what you describe?? then the seals in the relief valves need replacing.
You have a 2 part system, one's the trim(center rod) the others the tilt (shock looking ram)
The center one is very difficult to fix the other is no picnic either.
Like I said the problem you described is covered in the posts in the forum.
well like I said I’m not sure if the seals are bad I’m just assuming they are bc of the symptoms I’m having so I decided I might as well replace them as I’m sure they are OEM. I looked in the forums you talk about but couldn’t find anything describing what I’m going through but I will look again. And in that picture where are the relief valves located??
jerryjerry05
In the first pic, the black thing is the seal that's bad.
The red seal is a new one.
IF??? the seals on the rams aren't leaking??? No way would I try to FIX them.
