seattle scott
- Nov 1, 2011
- 113
motor came without a prop. I have the prop spacer ( that goes on before the prop) and one nut that threads on to the shaft. The parts diagram shows a second cone shaped nut called prop nut and a prop nut pin. There is a hole through the end of the shaft, where I assume the locking pin goes. So do I realy need the $30 cone shaped prop nut, or can I add a simple "castle" backup nut with a cotter pin?
