- Oct 25, 2011
- 25,250
Re: 14.5' Starcraft project
How do you plan to finish the deck once it's laid?
Paint, nautolex, etc?
Some prefer to counter sink & bury deck rivets in epoxy to prevent water intrusion at rivet.
I think Glen rivets the ply down w/out countersinking the rivet heads & lays the nautolex right over them. Hardly notices the 'bumps'...
JigNGrub will be along in a bit to strongly suggest you wrap the ply w/ nautolex 1st, then rivet the deck down 1 vinyl wrapped piece at a time. This leaves the rivets exposed above the vinyl, which makes pulling the deck, to check for a leak or do repairs etc, easy. Done neatly & with some fore thought, it looks great. I like exposed fasteners, the boat is covered w/ exposed rivets, right? But many don't like the look of the exposed rivets on the vinyl........
If you want to countersink the rivet heads, you don't need to drill much of a countersink, unless you want to bury them w/ epoxy over the top of the head. Barely a divot will allow the rivet to countersink below the surrounding surface when you cinch them down. Not even completely thru the top layer of the plywood laminations.
With 3/4 ply would you still suggest riveting to the floor without counterbore?
