Woodonglass
- Dec 29, 2009
- 25,930
Re: 14' Larivee restore
If you Gel then The Pot Gun from HF will work with the tip it comes from. You'll need a 60 gallon 3-5 hp compressor as a minimum. You thin it with Styrene and you can get it all from USComposites. 20 Mils thickness is what you're aiming for and that usually take about 4 coats. On a 14 ft boat that equates to about 3/4 gallon per coat so 3 gallons of gel would be needed. USComposites sells white gelcoat for $45 bucks a gallon. After you get it on thats when the work starts. LOTS and LOTS of Long Board sanding. You then finish with lots of buffing and polishing. All of this is from Research and Study NOT from experience. I PAINT cuz I'm to Lazy to GEL!!!
