140 Hp stern drive
RVB
To all,
Just purchased a project boat last week. It is a 1974 Larson 140 Hp I/O and it is setting in my driveway. I got the engine running and now I am working on the Outdrive. I noticed that I can rotate the prop by hand in either direction regardless of position (forward or reverse). Now I am not a boat guy so I don’t know the ends and outs of Outdrive. I have checked the magnetic and they’re reading 30 ohms on each.
When I put it in gear it spins fairly easy one way and has a little resistance the other. One other piece of information, when I start the engine up and put it in gear, the prop does not move but the engine start idling high. Any help would be greatly appreciated.
You have an OMC stern drive.----Well----30 ohms is way too much.-----Should be about 5/ 6 ohms I think.-----Sounds like a shaft spline is stripped.-----Fairly common.-----Time to take the drive apart.------Manuals are available.-----Your location ?
RVB
I am located in Las Cruces NM, about a hour northwest from El Paso, Tx.
RVB
Do you know where I could pickup a good manual? I have the OMC stern drive shop manual, but it seems a bit light on information.
The factory manual would be all you need.----Look for manuals on ---E-BAY.
