1990 looper
- Oct 17, 2012
- 8
Hi, I finally found the carb spitting and sputtering problem with my ol'looper and still have some questions. The gaskets that sandwich between the reed cage and intake plate failed. It looks like they were weak from fuel. Plus OMC only used two screws to fasten the box. One screw on each end. It happened in 3 of 4 cylinders and the fourth was on it's way. Two were sagging into intake plenum and the other two completely lost over couple inches of gaskets. Motor obviously sucked them in and munched them up. So, I believe that left the bottom edge of the gasket vulnerable to fail. I don't think any gasket adhesives were used in installation of the factory gaskets. Big question is: I honed the mating surface of reed cage on granite surface plate to make perfectly flat and smooth. The intake manifold has milled pocket for this surface. Should I use gasket and sandwich with quality gasket adhesive (The Right Stuff) or go commando
and use adhesive only?
