1) It was over heating.
2) Took stats and poppet out to test.
3) Tested, It ran good/cool.......Must be 1 of 2 or 2 of 2 items from #2 removed causing it to over heat!!
4) Ran/tested it again, It went to s**t/steaming/cough/puked............A water in cylinder leak now? WTF? Where? How? How to fix this next issue?
5) Putting new stats and poppet in hoping this fixes item 4? Impeller? Hmmmm, probably not.
Are you sure it is REALLY over temp? Understood the alarm, but you know electronics, it can be flaky. Get the parts back in, perhaps install a H20 pressure gauge in the mean time, if the alarm goes off again, second source temp measurements, we'll go from there.
It didnt went to s**t/steaming/cough//puked, has been like that since I got the engine,
not quite sure about the steam issue, but the coughing and hesitating for sure,thought is was some carbon build up .
Never had the alarm before, thats why I thought checking poppet and stats.
I am just asking: could a leak leting water into a cylinder/s cause the engine to overheat?
Sorry if I havent make myself clear on the explaining here, must be because I am slow Norwegian doing the best I can.
What kind of a second temp measurement do you recommend to use ,dont have access to a different original temp sensor.
Where can I connect a pressure gauge, and what pressure should I have?
