Brent<br /><br />I've got the same problem with my v6 150. Just seems a little lazy out of the hole and stumbles but once past 3000 rpm its fine. I've got the Merc decarb in a can but havent used it yet! Who makes the sea foam that you are talking about?<br /><br />GregOriginally posted by BF:<br /> after you get rid of the old gas, you might wanna try adding a can a seafoam to the next 5 gal's that you add. I have a V150 that had a mild bog (no stall or anything, just a noticable bog if you tried to accelerate quickly). A decarb (with deep creap) and running seafoam through it completely cured it. I take it to mean that the carbs had some varnish buildup and were a tad lean at idle. Easiest fix I've ever done!<br /><br />Brent
