Well my dad has an 86 Ranger bass boat with an 86 (I believe) Johnson 150HP motor on it. Anyways, the boat runs great once it gets going but we have had some problems with it starting and starting from stop lately. It seems that the boat wants to die when it starts and is idling when it has just started up, also when going into forward and first starting off it seems to bog and die some of the times. After the initial get go and the boat starts running if you shift into neutral it will idle just fine but if you cut it off it starts back the same way. Any ideas on what this could be?
Thanks,
Spencer
Thanks,
Spencer
