Re: 150 Johnson Flywheel removal
Another update:
Put my flywheel on, torqued it, and reset TDC per the book. Went to start it, no spark! Wha...huh?! Started troubleshooting at step one, but back up a sec.
When I first started troubleshooting, I never could get it to consistantly fail. The timer base had some bad readings and appeared very old, so I decided that it must be it.
Back to today. I went through the steps. 1. Eliminate the kill circuit, no spark. 2. Eliminate the rectifier, still no spark. Wait a sec, connect the ground and back to step one. 1. Disconnect the kill switch at the pack, SPARK! Reconnect...NO SPARK! Disconnect, SPARK! Oh BELOVED SPARK! YAY!!!!
So I need a new ignition / kill switch. I don't regret changing the timer base, otherwise the magnets could have screwed up some stuff. I probably loosened them by banging on it, but they would have come out soon enough.
Off to buy a switch. Will post pics soon.
