walleyehed
- Jun 29, 2003
- 6,767
Re: 150 johnson stalls
There is a fitting that screws into the tank that contains a check-valve....I have had 2 instances where this has colapsed causing restricted fuel flow.<br />It's usually a brass fitting screwed into an elbow exiting the tank and has the barb for the fuel line to connect to, which I will assume you are using 3/8" fuel line.<br />I've had 2 boats that sent me on a wild goose chase due to that darn anti-syphon valve.<br />I'd say it's worth a look and it's cheap.
