Going to add a jack plate anybody know where to connect to lift motor?
B boomer2506 Recruit Joined Jul 6, 2013 Messages 5 Feb 24, 2014 #1 Going to add a jack plate anybody know where to connect to lift motor?
Frank Acampora Supreme Mariner Joined Jan 19, 2007 Messages 12,004 Feb 25, 2014 #2 Re: 150 lifting points Don't understand your question. Please clarify.
B boomer2506 Recruit Joined Jul 6, 2013 Messages 5 Feb 26, 2014 #3 Re: 150 lifting points Going to add a jack plate so I need to lift and pull back the motor to install the plate.Found some videos on you tube and have found the answer.There is a hook tool that threads on to the flywheel for lifting.Thanks anyway.
roscoe Supreme Mariner Joined Oct 30, 2002 Messages 21,896 Feb 27, 2014 #4 Re: 150 lifting points Inside of the flywheel should be threaded. If it is, it uses a standard Mercury lifting eye. Mercury Mariner Yamaha Force Outboard Lift Ring 91 90455 1 Lifting Eye 1 1 2" 16 | eBay
