150 merc v6 bogs down at w.o.t.
j_martin
Re: 150 merc v6 bogs down at w.o.t.
I went back and read everything found were it said how to test I will try that tomorrow and I have a fiberglass tank but I am going to check the pickup tube and strainer if that don?t work going to rebuild the pumps they have a kit of under 20 with shipping and handling I would rather just get a new pump but I can?t find one.
There's nothing in the pump to wear except the diaphragm and valve disks, which are in the kit.
dsb
Re: Need help please
Fuel delivery problem. A small leak in the fuel line between the engine and the tank will take in air and cause this. So will something plugging up the fuel filter, or the pickup screen in the tank. A common problem is a loose or leaky pickup tube in the tank. If the fuel pump hasn't been serviced, that's suspect.
If the primer bulb sucks flat, it's a plugged screen. All the rest of the problems will just result in a bog.
DO NOT TRY TO RUN IT LIKE THAT. Just before it bogs, it's at about the right mixture to burn a piston.
Troubleshooting tricks. A piece of clear hose spliced into the fuel line to see any air getting in. A pressure gauge (15 lb) put in the fuel system. Should read 2 - 6 lbs at all times the engine is running. Each carb has 2 pipe threaded holes on the fuel rail. One is left with a plug in it, usually the lowest starboard one. Replace that with a nipple and hook up a temporary pressure gauge.
BTW, if you title your thread with something identifying the engine and trouble, like "V6 150 bogs at WOT", you will get more help.
hope it helps
John
Thanks very much fuel pump gaskets were in wrong runs better yesterday i was hooking up tach and now have no spark does tach have something to do with that if wires were crosed also is there a way to test both black boxes switch boxes thanks Darin
j_martin
Check the kill switch, which is supposed to have a lanyard on it, but might not.
dsb
that seems to be ok did that yesterday does tach have something to do with fire Also is there away to test switch boxes Darin
