bktheking
 - Jul 29, 2008
 - 5,057
Re: 15hp johnson only firing on 1 cylinder (help needed)
Couple "o" questions...
When you test the "pull the wire and motor dies test" , are you doing this right at cold start or once it's been running a while?
When you tested for spark was it the same time you did the "pull the wire and motor dies test"?
Pull the plugs and inspect, what do the plugs look like, is one plug brown/black and the other new? Swap spark plugs around and restest.
If you have compression and spark there is only one part missing, fuel. As a test, pull the bottom plug wire off and ground it using the plug tester. Remove the top plug and take some 50:1 fuel mix and spray it in the top cylinder (grab a new spray bottle for you testing, beer bottles don't work so well
). Replace the plug and start it up. If it fires and dies out then it sounds to me like you may have a reed problem. You have 2 pairs of reeds on the motor, top and bottom that feed fuel to the cylinders. If one set of reeds is bad you may not be getting fuel to that cylinder or too much.
