Re: 15hp Johnson
Look for air leaks in the fuel system, starting at the tank. If no leaks, it may well be that it's time to replace the fuel lines and bulb, especially if you have a cheapo bulb. The regulation OMC/BRP ones are quite good. The Tempo ones are quite bad.<br /><br />Bad check valves can do it.
