15hp only runs good cold?
ace420ace
ok did the decarb today and took out on the river ran fine at wot or close for 15min then all of a sudden sputter, miss ,sputter miss, so i pulled plugs and top 1 starting to build up carbon check spark to see if jumps 7/16 no spark top cylander am leaning towards that coil being faulty so far replaced other coil, powerpack,fuel filter,head gasket also decarb has cylinders withen 5 psi, I didn't think both coils would go at the same time. lol thanks
AlTn
hope another coil solves the problem....is the grounding point for that top coil shiny and clean?...ground wire attached solidly?
