16' 68 Starcraft Trident Project!!
Sea Raider I
Re: 16' 68 Starcraft Trident Project!!
Well im sure you saw the pics of the holes i found in the hull while grinding. I backed them up with mylar and foam taped them in place and applied the gel coat first before the layers of glass. I did end up using the oak as I didnt get much response and it seemed the best choice as it will be completely encapsulated as you stated. I cannot imagine having issues if its water tight... Too late to argue that now.. Anyway, I coated the back side with resin, then 1.5oz mat and sealed the edges. I mixed up bucked of resin with cab o sil, and 1/4" chopped fibers for renforcement and put a thick layer on the skin and transom then clamped using 2x4's Ive seen others on here use - they worked great. I had pb coming out of every orafice. I then mixed up another bucket o resin and filled in around the edges pushing that good stuff in all the way and smoothing it out at the edge. I have not started tabbing yet, but my plan for the backside is as follows: resin, 1.5 oz, 9 oz cloth, 1.5 oz, 9 oz cloth then finish it off with 18oz roving. I planned to extend the overlap to the boat about 2", is that sufficient??
Thanks for the questions, and interest!!
Woodonglass
Kool, Sound like you did an outstanding installation. I just worry about the Plywood. Even though it is encapsulated it still is susceptible to barometric issues and not having 100% waterproof glue could cause delamination. BE SURE to lay some CSM and resin on the top edge, and if she were mine I'd finish off with a Layer of Epoxy to make sure it is good and sealed. IF you Take extra care and make sure ALL screw holes and bolt holes are ALWAYS sealed properly then it should last for years. To finish off the Transom I'd recommend tabbing with 1.5oz with a 4" overlap first then a layer of your 9oz with a 6" overlap and then the Roving with a 8" overlap and then finish with a final layer of 1.5oz CSM with a 10" overlap. That should be plenty.
I made some drawings of how I do my Transoms, Stringers and Decks. Hope they help.
(Click the Pics to Enlarge)
Stringers
Transoms
Decks
Sea Raider I
Wood, Thanks for the info!!! Had company over so project sat for a bit. Have bilge box built glassing to resume soon. Two stringers along both sides are being built, will be glassing those in soon. OH YA oscillating cutting tools rock!! It eliminated a LOT of grinding... If anyone needs a pic to see what Im talking about let me know...
After deck is down cap painting to begin...
Sea Raider I
Getting closer!! Deck is down, pic doesnt show it but glassing deck is done. Had to lay down quite a bit of pb to fill the gaps, but she is almost there and solid as a rock!! Will post more pics after paint. Top shell near ready for paint, got the shell back on the hull and had minimal trimming to complete on the transom for proper fitment. Will keep posting pics up until Im on the water...
Sea Raider I
Getting closer!!! Deck paint down, topside body work done and prepping for paint. Got another free boat a 15' reinell with a perfect walkthrough window for my project!! Now to strip it and give her away...
I am still looking for the final piece, one which I fear I may never find...:mad:
I have attached a pic of the port side transom cap, I need the starboard side - if anyone can help or knows where I should look please jump in!!
Thanks in advance...IMG-20110705-00085.jpgIMG-20110705-00086.jpgIMG-20110705-00087.jpg
Sea Raider I
I can smell fish....
Worst still to come though Im afraid. Getting the 64' 40hp big twin running and hooked up, wiring, gagues and lights to come. The transom cap I am missing was quoted by a aluminum fabricator @ $350!!! My god thats how much I spent for the boat, trailer and motor... Anyway may have a lead on that dang cap, we'll see...
Just hope I make it out this season, the 8 ft sailing dingy just wont cut it..
