165HP Inline Six - 1969 vs. 1978 Interchange / Difference??????
Fordiesel69
I found a drop in engine from a 1969 boat. The manifold and valve cover appear different than my 1978. Would this engine be compatible. Any parts that are not the same I assume can just be swapped over?
I also understand that I would have to pull the head and update to hardened valve seats? Correct?
Re: 165HP Inline Six - 1969 vs. 1978 Interchange / Difference??????
Ayuh,... The motors should interchange, no problem...
swappin' heads is up to you...
If there's no other issues, I'd run it til there is...
