175 Yamaha Saltwater Series (2 stroke)
lucky7
Going to look at a boat with this engine, any problem areas? What should compression be?
robert graham
Re: 175 Yamaha Saltwater Series (2 stroke)
The best and only real way to evaluate the motor is with a sea trial on the water for about an hour, checking cold starts, idle, mid range cruising and wide open throttle.....Otherwise you could buy a pig-in-a-poke/problem motor. Good Luck!:)
James R
A compression test is always a good start.I would expect in excess of 100PSI and all cylinders within 8%. A low compression cylinder is a dead give away that the motor is in trouble
lucky7
Does anyone know the factory manuals numbers for compression?
99yam40
Yamaha does not list any compression #s in the manuals
