and it may run....Deo Volente. Recommend reading or rereading Zen and the Art of Motorcycle Maintenance -- probably a sermon or two in there, with illustrations from your outboard experience.
Well, I got the new head gaskets on.
I borrowed a SnapOn compression tester from my Ford mechanic friend. I finally got a stable, trustworthy compression reading.
the first two cylinders both measured 50 psi. That was with a cold engine, but I don’t think it warning it up will bring it up to spec from that far down.
Looks like ol girl needs a rebuild.
This was a project motor for a project boat. I have two other project motors, so on to my next victim!
it’s a 1998 150, (J150EXECD), which had compression problems (ironically). I did not want to bother with it, because it has plastic carburetor bowls that are leaking (warped) and I was afraid of the fancy electronic ignition condition system. But it’s worth a second look.
I will one day get this powerhead off the 1982 I have been working on, and send the block out for a machine shop to look at it. But for now it will sit in the backyard while I work on the other motors.
I’ll start a separate thread on the 1998. I’m new to Johnson/Evinrudes so I know I’ll have questions. Thanks for the help. I learned a lot, even though it didn’t turn out to be repairable for now.
