Re: 175hp Mercury slow to take throttle
may want to check the needle and seat that control<br />the float level in the fill bowl. could be some<br />crud in there. if you have not done a carb rebuild<br />in a long time, is a good idea to get done. faulty<br />carb can cause a lean condition and burn a piston<br />pretty quickly.<br />I had 2 props for my outboard, one for speed and <br />one with better bite for skiing/tubing.<br />good luck,<br />M.Y.
