- May 19, 2001
- 26,091
Re: Need help with interior work.
I merged your threads. With over 3 million (yes 3 million!!) posts it may be difficult for people to understand what post you were referring to.
Seal the edges of the plywood with allot of coats of marine varnish. Fill any visible voids with a 2 part epoxy and seal all surfaces of the wood up. Since it will be used for seating I imagine MANY stainless steel staples will be installed so the varnish is the easiest route. If you try to use epoxy and cloth ..... you may have a tough (near impossible) time installing staples.
I have another thread where I have been restoring an 18 ft fishing boat. I plan to have a professional do the bull of the upholstery work. However, I need to cover the marine plywood that makes up my consoles and casting deck. I would like to use carpet or vinyl upholstery material....but don't know how to finishes the edges of the plywood. I would appreciate any guidance that you might have on how to cover these vertical surfaces and edges. Thanks
