gearheadinWI
- Jul 9, 2004
- 31
73 18hp ongoing problem, have replaced points, condensor, one at cylinder coil, found lower main seal to be bad and replaced carbonseal, inner o-ring and the spring/washer/clip, rebuilt carb, replaced cracked vacuum line from top cylinder to intake, fresh plugs, top seal, maybe more.<br />It coughs even at idle, the fuel is OK because I ran 2 differnt 6hp motors on it and they were great.<br /><br />The repair shop had some orings and he thought they might go above the bearing beyond were I could reach but sent them home with me to see if I could find a place for them. I did not and the Seloc manual ONLY detailed that the carbon seal had a small oring in it and that the raised side goes up. At this point I am guessing that at least one of those larger orings I had does indeed belong in there somewhere and I am probably taking it all back apart. The shop I got the parts from said they varied a bit and he only knows exactly how they go together by how they came apart. Therein lies my problem, the whole carbon seal assembly had self destructed before I even opened the thing up it was shavings in the exhaust housing. Hopefully someone can give me some better info on placement of the large o-ring at the carbon seal. or if those are above the carbon seal out of my reach point me at what else might be the problem.<br /><br />Part of me hates throwing parts at it like this but it was used for years without any work atall the tuneup and carb work were just a good idea even with no problems and the upper and lower seals were obvious problems.
