18hp tohatsu 2-stroke M18C2 model no carb kit!?
32bit.flannel
Re: 18hp tohatsu 2-stroke M18C2 model no carb kit!?
Just for the record (and to help any future passer-byers) the carb rebuild on my M18C2 worked wonders for this motor. It's an extremely easy carb to work on, there aren't too many gaskets/seals and I was able to get by without harming any (which had been my biggest fear since parts seem to be hard to come by and not cheap if you do). The small Pilot Jet in the top of the carb, under that shiny plate, has such a teeny tiny little orifice that was about 90% clogged it's no wonder the thing couldn't idle. The Main Jet in the bottom of the bowl, and Main Nozzle, were also crudded up a bit. I soaked all the junked up parts in some Seafoam, used Throttlebody/Intake cleaner and compressed air to clean all passages out, and carefully picked the remaining gunk out of the small orifices with some small metal picks (then redid the TB cleaner/air combo on all parts). All said and done the mixture screw seems happy at about 1 1/8 turns out, and this motor runs like a champ! I took it out to the lagoons for a test run and it will idle at trolling speed all day long, and WOT it gets right up and goes. Very nice motor!
Thanks again Pvanv/Paul for all of your help.
pvanv
Glad it worked out for you :)
cdarbonne1
can someone help me with my outboard, i have the same motor, M18c2. and it needs a fuel pump, so I've been told, has new fuel filter, cleaned carb. runs rough under load.. only opens up every once and awhile.. Tohatsu/nissan says they don't sell the fuel pump or carb anymore.. how can i find something that will work? help please! thanks.
pvanv
-------------Please DO NOT reply to old threads or hijack existing threads. Old threads of a technical nature are like a library book, Do Not write in them.
1. Old threads should be considered archives and used for reference only. Do not reply to them.
2. Do not take over someone else?s thread (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new thread of your own.
3. If you have a question for the original poster (OP) and the thread is over 30 days old, send the OP a PM, he may not even visit the forums any longer, or may not notice your question in the old thread.
4. By starting your own thread, you will receive the maximum number of views by forum helpers that may not even notice your question when it?s posted at the end of someone else?s thread. And those answers will be specific to your particular issue.
Thank You for your cooperation
The Moderators
