gmarshall43
- May 5, 2002
- 216
I have a older Evinrude with the model 4423, at least that is what I can read. I think it is about 3hp from 1950. It has good spark and about 70 psi in both cylinders but it won't start. I have had it sputter, for a lack of a better word, but stalls out. I'm think the issue is in the carb and it feels like it is a choke problem but I do not see a choke. Is there one on that model?
Also there is a plastic fuel gage on the front but it leaks. How does that work, does the fuel flow through it or just up into it and stops at the top? Would this cause it not to start and are there replacements out there for it. I was told that it is not needed and I should plug the holes.
Thanks for any input,
Gary
Gary
