Re: 1950 Merc KG7 Gear Case Question
I have the pilot cap with upper seal from Dad's original gear case. The gear case I purchased did not come with one, and from the rough wear pattern on the gears it looks like it was run without one for a short time. I am very interested in your gear case. How do the gears look? How much are you asking for it? How can I contact you? I have 1 very good main gear, 2 good prop shafts, 2 good drive shafts, 1 super good housing, 1 decent housing, 2 water pumps, and bearings. Can't have too many spare parts! I have never seen a KG7 run, this ones lower unit has been a basket case since 1954-55. But it's got 130 psi on the bottom and 125 psi on the top. One compression ring is sticking a little facing the exhaust port on the top cylinder, but its free on the intake side of the piston so I think it will loosen up once I get her running. I have cleaned the carb and bought new coils and condensers for the Scintilla magneto. I remember Dad said he put new points in it before the lower got trashed. The gas tank has 2 small dents or so and the bottom cowling looks very good, just need to locate or fabricate a couple of those 1/4 turn fasteners.
