gmarshall43
- May 5, 2002
- 216
I have a 1954 10 hp johnson that I'm deciding whether to put new rings in it. It has become hard to start and the compression is about 60psi in each cylinder. I have cleaned the carb and changed out the points but doesn't run like it used to. It was a good running motor and I wonder if it would be worth it to change out the rings and gaskets. What's the opinion on this?
Thanks,
Gary
Thanks,
Gary
