cajuncook1
- Sep 3, 2009
- 559
I recently got a 1955 7.5hp Evinrude model 7518 (Basically raised it from the dead). She is running pretty good. But would like for her to idle just a little lower.
Back ground stuff.
Changed whole ignition, new Champion J6C plugs, carb kit (float is level and it is the original), replace the pinion clutch assembly (shock absorber), impeller and replaced the fuel and manifold(air hose) on the engine.. Have a good sound and functional pressure tank and the female connector to motor is repair and full functional without leaking.
Big Question:
Their is a leak coming from the carburetor. What can be causing this and or is this normal?(doubt it but just asking).
The icon is a picture of where the carb is leaking. The area is called filter outlet screw plug. It there a way to seal it, even though it is screwed in snug. Have you seen this before?
Click on the icon for a big picture....sorry a little off focus.
Thanks for any help!!!!
Here is a picture of the motor. (lightly cleaned)
Back ground stuff.
Big Question:
