1956 evinrude 7.5
steppinstone
I have purchased a 1956 7.5 hp evinrude and find that I have to do a ring job ,but I cannot find them because no one carries them any more the P/N is 378411 can any one out there tell me where I might be able to purchase them I want to get it in the water summer is coming fast .......... does any one know if I can get rings that fit from another year? :confused: Thanks Paul
samo_ott
Re: 1956 evinrude 7.5
How do you know you have to do a ring job? What's the compression numbers like?
steppinstone
I know because the rings are snapped ,I found that out when I tour the engine down . I have searched ebay looking for them but have had no luck . I have been searching the web every where but it seems no one carries them , I found someone in Oregon that has old pistons but does not sell the rings . Could I use used rings if I can't find new one's ?:confused:
samo_ott
Snapped. Ugh. did you try sea way marine in Seattle?
steppinstone
I found the web site and sent them a e-mail thanks let use see what happens keep your fingers crossed........:(
cc67
I would think that unless you have some personal emotional attachment to that motor you would be money ahead to find another motor. They are not that rare.
steppinstone
Is the ring set that expansive ? that it would not be worth putting into it ?
wbeaton
Peter at nymarine.ca sells them for $47 per cyl.
steppinstone
Would it be wise to replace both . Would it make it a different compression reading or would it make a difference ??????? cause one cylinder would have old rings and one would be new ????
wbeaton
It may make a big difference in compression, which is not good. However, its not uncommon to only do one cylinder. You should hone both cylinders, though. I know some folks only replace the top ring and reuse the bottom rings on really old outboards where the supply of rings is limited to very expensive NOS parts.
