1956 Johnson 30HP RDE-18
Restoring a 1956 Johnson 30hp RDE-18. Need a diagram for wiring in the starter. have 4 wires coming off the engine - Positive cable, negative cable, and the other 2 are for the kill switch for ignition? I want to wire in a key switch on/off and a button to start. I would assume a generic solenoid would work?
Ayuh,....... Welcome Aboard,...... I'm guessin' it's positive, negative, starter excite, 'n ground to kill the magneto,....
