Is the impeller drive pin in place?
The idles fine then speeds up and dies issue sounds like it's running out of fuel. Is the gas cap closed on the tank? Any leaks at the fuel fitting?
But the water tube is installed into the grommmet of the exhaust housing FIRST.----Then you install the lower unit making sure the tube goes into the pump properly !
And are you sure it goes into the upper grommet !
