I was thinking I might ought to send the hull south for a month or 2. Maybe down south, it'd be warm enough for Gluvit to be applied...........
Hey JB, How did you take off the engine?
Wow!! I am so glad that I didn't have to do all that to mine. Water drains fine from front to rear and there are no signs of roots or other debris jutting out from under the seats. I have wondered about the floatation but not enough to remove the bench caps. I did think at one time about cutting hatch doors in them for storage, but decided for what I will be using the boat for (just cruising around) I didn't need the storage. My other thought was to maybe just drill some holes just under the top cap lip where it wouldn't be noticed and spraying expanding foam in the cavity. I wasn't sure how well the foam would hold up and didn't want it braking apart and causing drainage issues. Anyway, my hats off to you for diving in. As for the coming down south part, its a nice brisk 26 deg. here this morning, but no snow.
You are welcome to come use the project corner of my shop, it's heated and well lit and the lake is just minutes away if you want to brave the wind and cold for a test run.
Mine is a 1/4 ton but looks similarYep, at LEAST 225lbs......My engine weighs approximately 225 pounds! I found a chain fall on CL for 15 bucks, so I'm gonna get that and reinforce the trusses by jacking them with vertical 2x4's. I will post that escapade! LOL, I will have to do it by myself. All my friends are too old to help. :-(
What we really need to work on these beasts is the forklift in that ^^^ pixView attachment 217407 Mine is a 1/4 ton but looks similar
Thanks Bear & Lokonn, nice to have you aboard........ It'll be a journey.
But rest asured there will be NO bow-ectomy nor any 'taking the top' off round these parts.
Checked in on the transom & epoxy, seems to be curing, mostly :facepalm: Re-check at lunch....
DOH. Unexpected 3.5hr road trip 1way for work just after lunch........... And back after dinner...........
Stopped at the shop on the way home & did a quick re-check of the transom. Additional areas have cured, but man, some is still fairly tacky.... Setup a supplemental heat source, so I'll have to check again 1st thing in the am..........
Not sure how fond I am about this whole epoxy taking days to dry situation when applied indoors & well above 60*...:watermelon:
And then a few more to fully cure.....
US Comp fast cure may be on the very near horizon.............
