Re: 1957 Evinrude 18 hp Fastwin Electric 18 carburetor rebuild
Well, here are my thoughts. They are free so take them for what they are worth, lol.
The idea that pressure tanks are dangerous is baloney in my opinion. I have never heard of one blowing up, ever. I have about 10 I use regularly, and know many, many members of aomci that use them, and have never heard of one casuing catastrophic damage.
However, I have done the fuel pump conversion on many of my motors, as well as many for others. Where it comes in handy is that good pressure tanks are getting harder to find in good condition, plastic tanks dont rust, and if you are running other motors with fuel pumps, it makes it easier to have 1 style tank. For those reasons I can see doing the conversion.
As far as doing your engine, it can be done in literally an hour. You will need a new connector which bolts to your motor which will accept the single line fitting. They are easily found. Then take the line that used to supply the pressure to your pressure tank, which connected to your old connector, and plug it with a bolt. It is no longer needed. Then remove a bypass cover, does not matter which one, upper or lower, and drill/tap it for a fuel barb. Mount a pump, then reroute the fuel lines. The line coming from that barb you just mounted supplies the pulses to run the pump. All done.
Now you could also do a more stock look by using a factory pump which mounts to the bypass cover. If you bypass cover already has the bosses for mounting the pump, you are set. If it doesnt, you can make an adaptor plate, buy a plate from F_R on this forum, or buy a bypass cover which will accept a pump. Drill/tap the outer holes to mount the pump to, then just drill out the middle hole for the pulse and mount the pump.
Just depends on which way you want to go. Ill post some various pics of conversions I have done.
