1957 fd-11 johnson lower keeps leaking
stwaller
I have a 1957 fd-11 18hp Johnson that my son and I are working on. We rebuilt the lower and everytime we put the skeg back on and fill it with oil it leaks out of one of the middle screws. I've drained the oil and took the skeg off and resealed it with more seal compound and get the same result. Anyone know why this keeps happening?​
Any close-up pictures of the condition of the surfaces around that screw.-----4 pictures.----Any cracks.
Obviously it had water in it and froze.----Any pictures of the inside.-----I would say that housing is warped to a degree from welding.-----Or mating surfaces are damaged , resulting in the leak.----Easy fix for me here.
stwaller
What is your easy fix?
Pressure test and see exactly where the leak is.---Then repair that leak with say ----" lumiweld" ---brazing rod.----Better yet is to replace that housing.
Crosbyman
if only one screw is leaking ....try easy stuff first... teflon tape on the threads and some sealant under the screw head Let the sealnt dry then pressure test
at 10psi with soappy water
jmho
stwaller
jmho
I will, thanks for all the help!
silverbul
Stupid question, why would you pressure test the lower unit when there usually is no pressure in the lower unit? just grease or 90 weight. blow out seals that are not leaking. jmo
silverbul
jmho
Doesn't the gasket go around all the screws? i believe this is a mating issue. jmo
But , but a lower unit does have pressure when motor is running.-----And they do develop pressure if out in the hot sun !!
silverbul
Lower units on a outboard are just like a differential on a car, truck. They do NOT build up pressure, only leak through gaskets, seals. Prove me wrong.
tphoyt
Diffs have vents do they not?
Any good mechanic would pressure test a LU for diagnostic purposes and to confirm a thorough reseal job. Jmo
