DeepCMark58A
- Aug 17, 2015
- 2,840
Does the lower unit shift with it off the motor? A rag wrapped around the shaft and a pair of pliers to grip. See if it shifts easily into all three positions. If so, then your issue is elsewhere. Also, there should be a stop in the shift/throttle linkage to prevent shifting if the throttle is advanced too far.
Not the case my lower unit only had forward and reverse off the motor, I sent the lower unit to a guru and was told no problem with the lower unit, I will be driving up to put it back on and learn what I am doing wrong.
