gmarshall43
- May 5, 2002
- 216
Is the prop from a 1958 7.5hp Johnson the same as a prop from a 1958 5hp Evinrude? I'm working on a 7.5hp Johnson and it starts up and runs well in neutral and the motor revs up good when I increase the throttle but when I put it in gear, it doesn't run right. The best way to describe it is the motor seems to bog down and doesn't run at full power when I turn the throttle up to full. I took the prop off and it will throttle up normally in gear. I took the prop off and used it on a 1958 5hp Evinrude and that motor runs normally at full throttle. I tried using the prop from the 5hp Evinrude on the 7.5hp Johnson but I get the same result as before. The two props look identical. Could I be using the wrong prop on the 7.5hp Johnson?
Gary
Gary
