1958 Evinrude 18hp Fastwin electric start
59 Fatty
What kind of fuel tank do I need with this motor? Also, if anyone has experience with this motor, is it a good one? It is in great shape, and looks awesome for almost 60 years old.
HighTrim
Pressure tank, unless converted.
Is it a good motor?! Heck yeah. Pound for pound the best in my opinion.
That motor stayed basically the same for the next 18 years or so.----One of the best motors you can own for easy repairs / parts availability for years to come !!!
bwkre
Not too many pieces of equipment last 57 years. If it's in good shape and looked after it will last for a long time to come. Also one of the best hp/weight ratio motors around. I've got a 1961 model and love it.
59 Fatty
Wow, that is great news! But....I have seen two types of metal 6 gallon tanks. One with a plunger type primer button. And the other with a bulb in the gas line. Which one will work, or both?
Additionally, the motor has no kill button, and there is no key switch, just the wiring harness. Looks like its in good shape, suppose I'll need to get a key switch?
fhhuber
Should have 2 lines from motor to tank. Sometimes a bulb in the fuel line for priming but that wouldn't be stock, the other line is pressure from the engine to the tank.
The pressurized tank system needs a non-vented cap and you need to exercise caution opening the cap.
Its recommended to update the wiring with one of the lanyard kill switches. While its not required for the old engine, the kill switch (if you actually clip it to yourself...) prevents a runaway boat. https://www.youtube.com/watch?v=K-v9V5qHxrM
lindy46
Is there a single fuel line going from the connector to a fuel pump, or is there a double line with one going directly to the carburetor and the second going to a port on the front of the block? If a single line, you need the newer style tank with a squeeze bulb in the line. If a double line, you need a pressure tank with the plunger primer.
So it has an electric starter? Is there also a starter solenoid under the cowl? You don't need a key switch - you can install a start button and mount it right on the front of the lower cowl area. See this post for a good wiring diagram which F_R provided:
http://forums.iboats.com/forum/engin...iring-question
oldboat1
Pics helpful. The '58 came with a kill switch (protrudes from the front of the pan, if it's there). But you can choke the motor to stop it. The plug and harness is pretty hard to find, so great if you have it (two assemblies, half on the motor, and half with the transom box and solenoid.) No charging system.
[edit. believe kill switch was only on the manual model, not the factory electric start. sorry.]
59 Fatty
No Title
There is no fuel lines here, nor do I have a tank. But I do understand all you all are saying. The magneto break is a great idea. I'm going to do that. Saucy photos of my new girl are now up for viewing. Yes there is a solenoid in the motor, and the wiring harness is ok. If it has a wiring harness for a key switch, would that also have a "kill" switch in the off position?
The way the motor is set up now you need the pressure tank.---Not hard to find depending on where you are.
oldboat1
manual start converted to electric. not sure what your harness looks like (no choke solenoid). might work fine, maybe with some tweaking.
ed. think I see a couple of black leads coming out from the ignition plate. Those would be for a kill switch -- can trace those and see how a PO wired them (both ground wires). Likely "M" posts on an ignition switch, if present -- the off position when the circuit is complete. Shorts the magneto.
59 Fatty
Great I'll look for a pressure tank this weekend. I'm in Naples FL.
The choke is manual, and I will look at those leads from the IGN plate. Marine engine .com shows those leads as you say. I think the easiest thing for me to do is just get a key switch (if the wires are correct for that). Choke is missing the knob off of the front, that is the only thing missing. Going to build another engine stand as well. I posted an ad on AOMCI for a pressure tank, I'll keep my fingers crossed that it is near me if I get a bite.
F_R
That is a manual start motor that somebody has added a starter to. The original stop button was in the hole that your cables are now passing through. Yes, you can use the two black wires to kill it. Just connect them to a switch. Or, you can stop it by simply turning the throttle grip toward "Slow" so far that it simply stalls.
oldboat1
It's a good project. Very simple starter circuit wiring, and easy to make from scratch if your existing system isn't what you want.
I have a '57 that I converted to elec. start, and opted for a button starter. (key start wasn't available on the factory electric until '58 -- not that it really matters if doing a conversion anyhow.) Could do a starter button and kill switch -- lots of options.
59 Fatty
No Title
Got the choke knob for 9 bucks in the mail. Looks like it was always there. The fuel tank is on it's way. Got it off ebay with lines and connections for 100. I have this, I don't know what to call it feeling again.....
64osby
100 bones for what should be a good tank, lines and connectors is not too bad on xbay.
Choke knob looks great.
I converted mine to fuel pump, using an existing tank. Easy on the pocket and runs good.
Looking forward to seeing yours run. They are fantastic motors.
I have most of everything to convert mine, just need to make the time to do it.
Nice work. ;)
59 Fatty
No Title
The tank has arrived! Yea!!! How can I be sure the tank air plunger is working properly, and tank is holding pressure? I built a stand out of scrap lumber last night. Had to take my mom to the ER in the late afternoon because she fell at the nursing home. She's ok, but I had to do something to occupy my thoughts. It's not pretty, so I don't know if I want to show it off here.
It is NOT an air plunger at all.------Test this way !!------Close tank cap.------Plug tank onto the motor.----Pull recoil 20 times.-----Release cap and listen for a hissing noise.-------Or fill tank with fuel.---Operate plunger to pump fuel into the motor.----Start the motor.-----Motor will now pump air into the tank and fuel keeps flowing to the motor.
59 Fatty
No Title
The motor is not in running condition yet. I was hoping to test the tank away from the motor since that has not been checked out yet. I'll be looking into that this weekend. I do understand the tank plunger mechanism now, thank you. The coils may be bad, the impeller may need replacing, and the plug wires look weak. But I am going to connect the battery and crank it 20 times before I pull it that many times. lol.
I made this stand out of stuff in the garage, try not to laugh too hard.
oldboat1
Nice stand!
Plunger is a fuel pump, like the bulb in a modern single line system. If the motor isn't ready for prime time yet, you could disconnect the lines from the motor (probably want to replace them with fresh lines anyway). Connect the tank as you normally would to run. Put a little gas in the tank and use the plunger to pump gas into a container -- tests the pump, but also cleans out the tank and hose. On the air side, you could rig a hand pump to get some air into the tank, then crack the cap a little like Racerone says (should hear a hiss) -- or pinch the line, put on a pressure gauge and see if it holds. Based on some info F_R provided in an earlier thread, there is not a lot of pressure supplied in normal operation (maybe 5 lbs), so don't overdo it. I don't think a MiTvac would work to test tank integrity because a check valve would interfere. (Maybe if it held a vacuum that way, you would know the tank was not leaking -- except through a bad check valve!)
Anyway, that might be a way of testing, prepping and generally tinkering with the tank before the motor is ready. I have an old motor connector end that I occasionally use to pump out tanks/lines.
Think you have a slightly earlier tank there. '57/'58 model would have a plastic plunger cap, I think. They work the same, and only some twit with too much time on his hands would mention a difference. If detailing the tank, I would just get the appropriate decals (script design for '57 and probably '58), and go from there.
