Re: 1959 Evinrude 35 Lark Golden Jubilee dies
Some would refere to it as an armature plate assembly or stator plate assembly. I have heard either term used. Anyhow........
While it is apart, it would be an opportune time to clean it up completely and relube the moving parts. This motor will be 50 years old next year and there's a good chance that the ignition system is aged and the parts need new grease to. There have been times, that I have had to trim off about a 1/2" off of each end of the spark plug leads, to give a fresh new connection for the boot kits and coils. Often times, I have seen the spark plug leads were not fitted inside the coil connections properly and a bad connection will soon occur. The cabling inside the spark plug leads often start rusting and often give trouble, only when you put the boat on the water.
I did see tim_duracraft state that he is getting plenty of fuel, so this looks like it is an ignition issue. Motors like this are often responsive and come back to life quickly, if the ignition system and fuel system are in proper working order. Often times, these motors sit out on the end of people's houses for years on end, then they take them out and wonder why they don't want to run right. After all, there aren't too many cars this age out runnin' around. Sure, outboard motors, don't get the use that cars do, but lack of use, is a form of abuse and things will deteriorate quickly just sitting.
So far, I have never had trouble bringing these motors back to life, with a proper tune up, unless there is a loose rod bangin around, or a frozen lower unit.
Also, I have seen coils that sparked, but the cylinder would not run on it. Just because it sparks, doesn't mean it's good. These are cases where you need to pull it apart and see that the coil is not arcing out on the Armature Plate.
