1960 16' Starcraft
lamphega
Re: 1960 16' Starcraft
Great old Starcraft. If I wasn't in the middle of my old restoration I would be interested. But more info on the performance rocket there...any video of it running-whats it like to drive?
Gasturbine
The turbine makes 1350 hp, and hurls the boat down the water at 145 mph, while going 0 to 100 in about 7 seconds.
We got the jet from a crashed Huey helicopter, and through the Cassell v-drive, it throws a 24?/29p screw via an Arneson surface drive.
The jet spins at about 28k rpm, and has a built in 3:1 reduction unit. That runs into the 1:.83 overdrive (v-drive) which ends up at about 6k screw rpm.
We also installed a disk brake on the output shaft. This not only allows the shifting of the v-drive, but also allows us to stop the output shaft, load the turbine, then release the brake, allowing great hole shots. :D
The boat is turn key ready, smooth, and built right. While we can build piston engines that make this power, the rebuild schedule would be high. The great thing about turbines is the little wear they produce, and that they are right at home running at 100%, even for long periods of time. Try that with your 400+ hp piston engine...you'll end up picking up the pieces.
We run at an unlimited speed/hp reservoir, and the best fun is these 60mph+ jet skis rolling up on us, posturing to race. We just roll on the throttle a bit...bye bye bumble bee. :D
The biggest downside is the mileage. It drinks 100 gph at speed. We have 3 tanks...2 60 gallons on each side, and another 40 in the bow. It was not unusual to spend $300 for fuel for a short afternoon of fun. Noise is also an issue. It is VERY noisy. He had to install helicopter communication headsets to talk to each other.
The boat feels real good all the way up to 100 mph. After that, things can get a white knuckley, but we learned keeping the boat trimmed down a little make it more stable, even tho we are probably losing a few mphs.
Once we made a high speed run from one end to the other, and about 10 minutes after we stopped, this water cop come charging up at full throttle (40mph) comes to our side and forcibly says "Do you have any idea how fast you were going??" to which I looked at the GPS and calmly said "Yup, 137 mhp." He gave us a little lecture on how he could still write us up for "to fast for conditions", but after he calmed down, he gave us compliments on the boat, and directed us to be careful. :rolleyes:
Here the only video I could find...its rather old and shaky, sorry...
rrumba
Ensign
that is one awesome looking starcraft you have there. That would be one to hold on to and not sell IMHO.
so what is your gas mileage on the jet? lol:D
Gasturbine
I know, I know, but Im just not into the retro thing or restoration, so I will be selling it. Id rather have someone to have it who has the passion for it anyway.
I posted the mileage on the turbine boat...100gph at speed. Thats a staggering 1.5+ gallons per minute. :eek:
Gasturbine
What is this petcock...is it the speedo pick up? If so, am I missing part of it. It does not protrude past the bottom.
It goes into the second pic...looks like some sort of filter maybe?
It then goes into what looks like a valve...can someone help me out?
Sorry about the crappy pix. :(
Thanks!
Woodonglass
If I'm not mistaken it's the transducer for your Old Style Fish Sonar
Gasturbine
Thanks Wood, but I had already found the transducer. When I opened the petcock, some water did run out.
No big deal...I will have to trace the line out...just thought someone here might know.
Thanks again!
-Chris
