jallenlots
- Sep 2, 2011
- 41
Re: 1960 40hp Johnson RDS 22 motor cover? First project!
Ran into my first problem. And it's a problem that about took my fingers off. How in the world do you get the recoil spring back into the housing while one end is hooked to the housing, and one end is hooked to the pulley. I went at this @#%$^@ for about 3 hours today and ended up with a huge greasy mess, and a recoil starter assembly in 3 pieces (housing, pulley, spring). I just don't see how it's possible to wind this thing when one end is fitted around a peg in the housing and the other is fitted around a peg on the pulley. Even if I were to get the spring wound into the housing, how in the heck would I get the pulley-end peg in place without totally uncoiling (which is very dangerous as it turns out) that spring?? I was about a skip and a hop from taking this whole thing and tossing it into a fire pit, because watching it burn would've brought me a LOT of joy.
HELP BEFORE I GO INSANE AND THROW THIS THING IN THE DUMPSTER!!!!
Recoil starter has to be the most difficult motor maintenance ever in existence if you're lucky enough, like I was, to have it pop apart on you. At this point I would rather set this motor in the attic until I come across a new entire starter unit while walking down the street.
