1960 johnson 75hp V4S-12 starter
Undersquare
I'm looking for a starter for a 1960 johnson 75hp V4S-12 and am not having much luck. Are there newer aftermarket starters that would work? I saw one for a mercury that looked very similar. Thanks for reading.
oldboat1
Arco, maybe. Unless somebody ripped yours off, might describe the issues with yours. Maybe some folks here can give you suggestions for repair.
Your location.-----There are other V-4 models up to about 68 that will work as well !---If in Canada----evinrudeparts.ca-----might be able to help you.
Undersquare
I'm in northern California. The model number of the starter is autolite mdw-4103m. I called Arco and they couldn't find anything. I don't know much about rebuilding starters hopefully that's not my only option.
